squeak from hell
Old Jun 3, 2010 | 03:17 PM
tara's Avatar
i ran the engine hot till all the water was gone. i just drove the car from california to idaho and its been having this problem since before the trip.
do you think sanding it would help?
Old Jun 3, 2010 | 03:33 PM
Well....the car didn't come from the factory with rust and chunks on the pulleys, so it can't hurt.
If you still have a squeak, at least you'll know what it's not!
Old Jun 3, 2010 | 03:37 PM
tara's Avatar
that true. i'll go try it.
Old Jun 3, 2010 | 03:42 PM
Honestly, I'd be surprised if the squeak went away. But, that kind of pulley crud bothers me, I like clean stuff.
Reading your previous post, you might not have a belt squeal. It might be an idler bearing, or even your alternator even though it's fairly new.
When you replaced the tensioners, did you replace the pulleys too?
Old Jun 3, 2010 | 03:52 PM
tara's Avatar
yeah still squeaking but it looks cleaner. =]
but isn't it true that if you have a bearing problem the squeak would continue squeaking when you put water or belt dressing on it? putting water or belt dressing on the belt helps it grab.
Old Jun 3, 2010 | 03:56 PM
Were you pouring it on like a bucket (what my mind saw), or were you keeping it more localized to be only on the belt?
Old Jun 3, 2010 | 04:09 PM
tara's Avatar
it as in the break cleaner/water? localized. litte squirts. and i used a toothbrush to get the stuff out of the grooves.
Old Jun 3, 2010 | 04:17 PM
Have you fed the chipmunks lately?
Do any of the pulleys feel loose, any brackets got tweaked, anything to cause a belt tracking problem?
I love the Gatorback belts too, never had a squeaker.
Old Jun 3, 2010 | 04:33 PM
tara's Avatar
tried them all. they all look ok. and they look pretty dead on. i have got a couple peoples opinion and they all say the same. i could bring it to a shop or somewhere where they measure them with the laser thing but i dunno.
the only thing slightly fishy is the alternator pulley squeaks lightly when i spin it.
Old Jun 3, 2010 | 04:43 PM
  #20
And that shouldn't be squeaking. Look at the fins on the alternator fan, make sure none are tweaked and dragging on the case.
Those'll squeak like a summmabeach if any are dragging.
v64thgen
Jan 13, 2015 07:29 PM
jjhenderson17
Aug 13, 2010 06:19 PM
4thgen_noob
Sep 14, 2009 06:32 AM
tamuaggie2007
Aug 21, 2008 10:16 PM
moyer48
Jan 19, 2007 12:15 AM
