squeak of death
Old Aug 8, 2010 | 09:45 PM
jjhenderson17's Avatar
Default squeak of death
SO I drive my 99 camaro 3.8l v6 as an everyday car and about a week ago I noticed a squeak upon startup as i looked into it; my belt is fairly new although it is a duralast, my pulleys are all good except my AC pulley, the outer housing clutch spins and makes slight grinding/squeaking noise, I drove the car and heard the squeaking right at startup and I turned on the AC and the squeak went away, could this be the AC pulley? AC clutch? Tensioner? belt? ideas? suggestions?
thanks for any feedback
Old Aug 8, 2010 | 10:22 PM
RedKnight's Avatar
It wouldn't hurt to replace the tensioner. Mine began making an awful noise a few years ago, and a replacement solved the issue. Even if the squeal isn't coming from the tensioner, it's weakened state could cause the belt to slip on another pulley.
Old Aug 8, 2010 | 10:41 PM
CNCman's Avatar
Get a stethascope from the parts store for 6 bucs, You can better isolate sounds with it. It is probably the A/C clutch though.
Old Aug 8, 2010 | 11:25 PM
doinnslow's Avatar
ac pulley will make noise when its on not off, id go with tensioner, even though a duralast belt isnt the highest quality it shouldnt squeak if its new
Old Aug 9, 2010 | 12:33 AM
Originally Posted by jjhenderson17
...my pulleys are all good except my AC pulley, the outer housing clutch spins and makes slight grinding/squeaking noise, I drove the car and heard the squeaking right at startup and I turned on the AC and the squeak went away...
You pretty much answered your own question right there. It's not uncommon for a worn A/C clutch to make noise when disengaged as the sloppy outer pulley rubs on the inner hub. When the clutch is engaged, the two parts are turning as one and the squeak went away. If the A/C compressor was bad (a bad bearing), it would make a groaning noise while the clutch is engaged. Put a couple of drops of oil between the pulley and hub and see if the squeak goes away. Be sure not to slop oil on the belt. Sounds like it's the onset of the clutch going, and oiling it will buy you some time.
Old Aug 13, 2010 | 06:19 PM
Hey thanks guys, I'm gonna replace tensioner and belt and try putting some oil in between clutch and ac where could i get a new clutch?
v64thgen
Jan 13, 2015 07:29 PM
tara
Jun 3, 2010 04:43 PM
4thgen_noob
Sep 14, 2009 06:32 AM
moyer48
Jan 19, 2007 12:15 AM
97z6shooter
Jul 17, 2006 11:14 PM
