Infamous Overheating Issue - Quick Question
Old Aug 8, 2010 | 10:34 PM
LethalQuicksilver's Avatar
Default Infamous Overheating Issue - Quick Question
Hey All,
I've read through every post I could find about the infamous overheating issue with many 4th gen Camaros. I have a 97 SS, and I have a quick question for the group:
My engine temp runs great while driving on the freeway, but as soon as I begin idling or get stuck in traffic, the temp climbs, and climbs, and climbs. It drops back down to normal temp when I turn on the heater, but otherwise it wont stop and will redline.
Is this the ECT sensor being bad? I don't believe it's the relay or fan motor since everything works great when the heater is on. Unless a different relay is used to force the fan on when the heater is used?
Thanks in advance!
Tom
Old Aug 8, 2010 | 11:06 PM
the fan will come on with the a/c, so your fans are not coming on at the right temp or not at all? do they only come on when the a/c or heater is turned on?
Old Aug 10, 2010 | 08:58 PM
They only come on when the heater or a/c are on. Otherwise I've got nothing
Old Aug 11, 2010 | 12:43 AM
could be the temp sensor. on mine the temp sensor is on the water pump and the temp gage sensor is on the driver side head between 1 and 3 plugs. im not sure if the 97 has two as well. check and if you have two you can test em.
Old Aug 11, 2010 | 12:44 AM
Old Aug 13, 2010 | 10:34 PM
Remy's Avatar
It wouldn't hurt to check the relays for the fans. One guy suggested that I swap the the three relays for the fans. Fans kicked on after moving the relays around on mine.
Old Aug 13, 2010 | 11:24 PM
CNCman's Avatar
Welcom to our Forum! Parts manual may help with some things.... enjoy
http://www.z28.com/LyleA/93-02%20%20...s%20Manual.pdf
greenmachine96
Aug 18, 2012 09:53 AM
gzilla95
Jan 5, 2012 10:37 AM
chrshadil
Nov 5, 2009 10:21 AM
cbrenn71
Oct 12, 2007 01:27 PM
IROCZJON
Aug 24, 2006 06:43 PM
