Speaker Wiring Help
Old Mar 18, 2012 | 10:46 AM
tarheel's Avatar
Default Speaker Wiring Help
I have a 98 Z28. I was going to change the front speakers out and put in components. When I took the speaker out it has 4 wires going to it. 2 red and 2 black. And a plug that went into the red and black wires with a blue,yellow,black and lt green. I need to know if it will matter which i use for input or can I use any of them?
Thanks
Old Mar 18, 2012 | 06:07 PM
androzer's Avatar
http://www.the12volt.com/installbay/...etail/488.html
Old Mar 21, 2012 | 01:23 PM
tarheel's Avatar
I found that same page before. It didn't help. Said wires are gray and tan. I don't have any that color and have 4 not 2.
Old Mar 21, 2012 | 01:45 PM
Mikey.'s Avatar
Do you have the factory monsoon system? If so it's wired for 4 ohm speakers. Could always pull the head unit and do a continuity test between wires to figure out what you're working with.
Old Mar 21, 2012 | 02:21 PM
tarheel's Avatar
It has an aftermarket radio. Not sure what it had before.
Mark212
Feb 8, 2014 07:44 PM
Mtm5237
Dec 30, 2010 12:39 PM
Mtowles
Mar 19, 2010 12:03 PM
BIG.D
Aug 28, 2008 08:58 PM
ridin_low07
Apr 14, 2007 09:13 PM
