spark plug and wire question
Old Apr 3, 2008 | 12:41 AM
Spartan66's Avatar
Default spark plug and wire question
ok so my grandpa thinks that i may have a bad plug and its been awhile since ive changed em out so i wanna get new plugs and new wires. I was lookin at this LT1 MSD/NGK Spark Plugs & Wires Combo but it has two types of plugs TR-55 and TR-6 but the TR-6 say its colder one heat range than the TR-55 does that mean i should just stick with TR-55? The combo includes: 1 Plug Wires and 8 NGK TR55/TR6 Plugs for under 100 bucks.
All in all two questions TR-55 or TR-6 and i know MSD is a good brand but how about NGK? I read apositive review on this combo but there was only one so tothoseof you who are more knowledgeable is this agood combo?
Old Apr 3, 2008 | 08:43 AM
EarlR's Avatar
Default RE: spark plug and wire question
NGK supposedly makes a good plug - I've only ever used NGKs in my 240SX race car, with no complaints, and just put a set of the Iridium IX plugs in the Camaro, but they haven't been in there long enough to tell anything. On the heat range I would stick with a stock type plug unless you have done a lot to the engine, or regularly run it hard for long periods. A colder plug will generally be a little harder to igniteunder normal operating conditions; probably not enough that you would notice but still why push the issue.
Now, as for the MSD wires... I had the car on a dyno last week, and it was acting a little eratic; one pull would be ok, the next one (with no changes to the car) would be down as much as 8-10 ft. lbs. on torque, and we couldn't figure it out. One of the things the shop owner suggested was to ditch the (new) MSD wires, that they had seen people having a lot of problems with them. Now normally I would take that kind of advice with a grain of salt, but these guys have been building and working on race cars for many years, so I give their comments a little more credibility than I might give some others. I haven't had time to try changing the wires (they suggested just a good set of oem-type wires), soI'm still not sure what the problem is, but it isstill there so I can't rule out the wires. I've also browsed a couple of other Camaro forums, and have heard other guys complaining about problems after installing MSD wires, so you can take that for what it's worth.
Old Apr 3, 2008 | 08:57 AM
Spartan66's Avatar
ah, ok. ill be avoiding the msd wires then. Thanks. Have you heard anything different about Accel or Taylor? If all else fails ill just get some AC Delcos.
Old Apr 3, 2008 | 05:37 PM
LT1RUNNER's Avatar
I had the Taylors and 1 of the the boots got dry and brittle from the heat of my headers and actually started to fall apart! Luckly I still had an MSD that I replaced with the Taylors laying around and used it. That's about the only biff I had with the Taylors. Come to think of it I still have the MSD on the engine! 1 MSD and 7 Taylors hahaha!
Old Apr 3, 2008 | 07:19 PM
kamaro68's Avatar
I ran Accel on my 68' with no problems.
I have...crap, I can't remember...MSD or Mallory on my 68' now and have no problems. I think they are MSD, I am not a fan of Mallory.
I will probably go with the AC Delco OEM for my 94'.
I have NGK in my 68' also right now with no issues at all.
Old Apr 3, 2008 | 08:18 PM
Spartan66's Avatar
ok.... well.. for the price i think ill try that MSD NGK combo... if something else arises ill know what to replace first.. the wires...
Old Apr 4, 2008 | 11:31 PM
TEXASMAN1's Avatar
I BOUGHT THIS COMBO WITH THE TR55S. I HAVENT PUT THEM IN THOUGH. I DONT THINK A BRAND LIKE MSD WOULD **** THINGS UP. ID TAKE THE PLUGS ****ING UP.
Old Apr 5, 2008 | 12:35 AM
MassholeLT1's Avatar
I have had horrible experiences with Accel plugs, I would stay away from them
Old Apr 5, 2008 | 02:59 AM
Spartan66's Avatar
ok thanks. Yeah ill just go with the combo and see where it takes me.
jackss00
Aug 6, 2011 08:10 PM
sebi1990
Oct 10, 2010 10:24 PM
Mr_Exacto
Mar 1, 2010 12:30 PM
skylinrcr01
Dec 31, 2008 02:49 PM
domo556
Oct 13, 2008 06:34 PM
