spark plug wire fit
Old Dec 6, 2008 | 03:16 PM
skylinrcr01's Avatar
Default spark plug wire fit
will these fit on my 3800?
http://www.jegs.com/i/JEGS/555/40210/10002/-1
Old Dec 6, 2008 | 03:57 PM
02StanGT's Avatar
Default RE: spark plug wire fit
Iftheyare the kind where you cut the wires to size and crimp them yourself, then yeahthey will fit. If they are premade, who knows if they will have six of the right sizes...
Old Dec 6, 2008 | 04:55 PM
by size do you mean length of the wires?
Old Dec 6, 2008 | 05:03 PM
02StanGT's Avatar
Yes. They have "universal" kits, in which they have a 8 long wires that you cut down to size after seeing how much you need. They are a little cheaper than the direct fit kits I believe, since you have to cut and crimp your own wires.
Old Dec 6, 2008 | 05:09 PM
i think ill just get those. after all the worst that can happen is i have a bit of exess wire in my engine bay right?
Old Dec 10, 2008 | 02:21 PM
well after a couple hours and a few cut and lots of oil getting all over my arms i got them on, and they work great.
Old Dec 10, 2008 | 02:30 PM
02StanGT's Avatar
Looks good.
Old Dec 10, 2008 | 03:42 PM
thanks. still is misfiring tho . why arent you a mod your always in the tech sections?
Old Dec 10, 2008 | 04:21 PM
evilkal's Avatar
He's a noob =P Wires looking good though man. You check your coil packs? Move the pack attached to the cylinder misfiring around and see if the misfire goes with it.
Old Dec 10, 2008 | 04:30 PM
good idea. the only problem is that it occurs under load and 1/2 throttle
