spark plug wire fit
RE: spark plug wire fit
Iftheyare the kind where you cut the wires to size and crimp them yourself, then yeahthey will fit. If they are premade, who knows if they will have six of the right sizes...
by size do you mean length of the wires?
Yes. They have "universal" kits, in which they have a 8 long wires that you cut down to size after seeing how much you need. They are a little cheaper than the direct fit kits I believe, since you have to cut and crimp your own wires.
i think ill just get those. after all the worst that can happen is i have a bit of exess wire in my engine bay right?
4 Attachment(s)
well after a couple hours and a few cut and lots of oil getting all over my arms i got them on, and they work great.
Attachment 41022 Attachment 41023 Attachment 41024 Attachment 41025 |
Looks good.
thanks. still is misfiring tho :(. why arent you a mod your always in the tech sections?
He's a noob =P Wires looking good though man. You check your coil packs? Move the pack attached to the cylinder misfiring around and see if the misfire goes with it.
good idea. the only problem is that it occurs under load and 1/2 throttle
