something wrong after opti install
Old Aug 26, 2012 | 06:16 PM
ground strap goes from the block to the frame. the ground at the front of the motor on the driver side should be just below the coil
Old Aug 26, 2012 | 06:38 PM
Greg08's Avatar
Yep , but there are ttwo other wires, with metal hoops at the end. Idk where those goes :[[
Old Aug 26, 2012 | 06:40 PM
Greg08's Avatar
Its a 95
Old Aug 26, 2012 | 06:56 PM
i have mine grounded at the same place as the strap. one of the mounting bolts on the coil has a threaded top for a ground. what color are the wires
Old Aug 26, 2012 | 07:00 PM
Greg08's Avatar
Kk, I need to take the 3 grounds off the coil heatsink and ground them under the coil . I hope that helps the z28 fire up. If not, ill check for spark at coil and plug wire ends. And if I have no start still, ill have to take the opti back off. I could have sworn that I had thst **** lined up
Old Aug 26, 2012 | 07:07 PM
Old Aug 26, 2012 | 07:14 PM
Greg08's Avatar
Ok friend :] I've seen those before. Ill let you know! I appreciate u and the rest of this forum being so helping
Dana
Jul 16, 2014 07:31 PM
fasttony350
Jun 30, 2012 12:52 PM
wes232323
Aug 12, 2010 10:06 PM
Rhino0039
Jan 5, 2009 10:15 PM
SickSickSick
Jul 4, 2006 07:17 PM
