did i install the tranny wrong?
Old Jun 24, 2012 | 10:18 AM
fasttony350's Avatar
Default did i install the tranny wrong?
i just swapped motors (3.8) and left the flywheel that was on the new motor which is just a bit skinnier then the one i had. then i installed the converter, then the transmission, then the drive shaft. i then took the car off the lift and went to move the car. with the tranny in neutral you can push it foward but can't push it back? i even installed a new drive shaft yolk. i then tied a rope to the rear to another car and tried to pull it and it wouldn't budge...wtf went wrong???
Old Jun 24, 2012 | 10:48 AM
slick's camaro's Avatar
Sounds like you did not sync your trans selector cable. I cant link it right now cuz I'm on my phone.
You need to recheck your work before you crank her up. Your torque conventer is not engaged fully onto the transmission. Slide the torque converter onto the transmission first untill it doesn't go any further. Rotate the tc back in forth untill you feel it slide further into your trans Twice. If its not completely engaged your pump will be ripped apart. After that then you can bolt your trans to the back of the block and tc to fly wheel.
Old Jun 24, 2012 | 11:08 AM
thank you. i will do that
Old Jun 24, 2012 | 01:09 PM
look at number 41 here 4th Gen LT1 F-Body Tech Aids
Old Jun 30, 2012 | 10:10 AM
Based on what you typed you did not align the torque converter to front pump. This will wipe out the transmission.
https://camaroforums.com/forum/93-02...problem-69367/
Old Jun 30, 2012 | 12:52 PM
BasicConcepts's Avatar
Technical User
ya sounds like your going to need a new tranny. when you dont align the tq converter right it will destroy the pump.
Dana
Jul 16, 2014 07:31 PM
mlb5769
Apr 13, 2013 11:37 PM
Greg08
Aug 26, 2012 07:14 PM
nebraska83Z28
Nov 8, 2009 09:17 PM
SickSickSick
Jul 4, 2006 07:17 PM
