Some Exhaust Questions...
Old Jun 6, 2007 | 10:32 AM
hackson's Avatar
Default Some Exhaust Questions...
hello, I am planning on getting a v8 camaro probably 99-02 in the near future. V-8 SS
I have some questions about the exhaust.
I noticed with my research that from the engine it goes into the cat and then runs back into a muffler and has 2 pipes coming out of that muffler for dual exhaust. Now this is not "true" dual exhaust i know.. But how much crapier is it going to sound than true dual exhaust, if i put a flowmaster 40 on it...and also how much of a diff do you think it will make sound wise with a highflow cat?
Is it possible / do they have some setups to where you can put true dual exhaust on 99-02 camaros? Perhaps with headers, even if you have to put a couple of high flow cats on...or is there not enough room under the car / you would bottom out easily... if so what do you think it would cost to convert?
I am trying to get an idea of what this exhaust setup is gonna sound like. As a good comparison I used to have an 84 Monte Carlo SS where it Y's off after the cat into 2 exhaust tubes. I had a hollowed cat and glass packs.....it was a 305HO.......any ideas what a 99-02 camaro 350 w/ flowmaster and highflow cat would sound like compared to this setup?
My concern is having a decent sound to the exhaust and it being able to breath properly
Old Jun 6, 2007 | 10:49 AM
98ss4REAL's Avatar
Default RE: Some Exhaust Questions...
it will sound good with the muffler and high flow cats, and stock exhaust isnt a bad sound just quieter then true, all u really need is a good cat-back exhaust system screw mufflers and go straight pipe check out the slp loud mouth 1 cat back system if u want a mean sounding car thats wat i have(if u have e-missions then check out the rules for exhaust mn has no e-missions thnk god), u can run true dual u just need to have a shop do it, not sure if u can get true i live in mn an shops will only do a h/x pipe for u. there is anof room under there but u need to be careful if u get the true dual pipes for scraping them on stuff justa f.y.i... and the ls1 is 98-02 not 99-02 just to let u know.. cant forget 98 man lol.
Old Jun 6, 2007 | 11:32 AM
hackson's Avatar
i skipped 98 cause I most likely wont get a 98...i am aware that the 98 is an ls1
Old Jun 7, 2007 | 11:10 PM
95slvrZ28's Avatar
You can fit a true dual, but it's not going to benefit you anymore than a good 3 inch cat back unless you dump it before it goes over the axel. An exhaust that it's "true dual" doesn't sound crappy...it's just a slight bit quieter. If you want some sound references, you can ceck out www.ls1sounds.com
Old Jun 8, 2007 | 01:02 PM
nickdotcom's Avatar
TSP makes a true dual setup this will bolt right up if you get long tubes
http://www.texas-speed.com/shop/item...6&catid=56
i considered this option but decided to just go LM1
kisensharp
2010+ V8 Tech
Dec 4, 2014 09:05 PM
zelda782
May 16, 2012 12:29 AM
Mikey.
Mar 27, 2011 08:54 PM
WIspartan1026
Apr 25, 2010 07:39 PM
thormotox448
Apr 5, 2006 03:41 PM
