So what does it mean if the BCM fix didn't work?
Old Mar 31, 2013 | 12:55 PM
Basic96Camaro's Avatar
Default So what does it mean if the BCM fix didn't work?
Like the title says, I took the BCM out and reflowed the 5 points shown in the sticky and I still have the same symptoms, interior lights flicker when cold, when those get done flickering, then I put in the key and turn to on, then the seat belt chime/light flicker for a while, then if I put on the seat belt and try to start it then I get the security light on the dash and nothing else. Not sure what to do now, any suggestions? Thanks in advance and I can post pics if needed.
EDIT: And at the end of the year last year the radio started cutting out too, another tell-tale sign of a failing BCM.
Old Apr 1, 2013 | 10:34 AM
get the magnifing glass out and look the bcm over again for any cracks. might consider a redo an hope it didnt connect right.
Old Apr 1, 2013 | 07:38 PM
Alright 3 tries later still no dice. Is it stealership time? :/ is there anything else to try as a last ditch or should I just bite the bullet and get one?
Old Apr 1, 2013 | 07:58 PM
nothing comes to mind. maybe one of the other guys has a light bulb go on over em.
Old Apr 2, 2013 | 04:56 PM
Alright so I've tried 4 times now, including reflowing everything this last time, with still no favorable results. Could I just drop in a new bcm, ordered from gmpartsdirect or is it not that simple? I know these are specific to the cars specific options, but they only have it with or without keyless entry, 2 options total for my year. I know I will have to do the key learn procedure, but I think I can handle that, but is it a simple drop in, plug and play? I apologize, as this information is probably out there, but I can't seem to find it. Thanks for any input all.
Old Apr 2, 2013 | 07:16 PM
post in the bcm fix thread. maybe massey will respond.
v64thgen
Apr 23, 2014 10:25 AM
minex
Nov 25, 2011 09:28 PM
