Shift kit?
Old Apr 3, 2011 | 06:34 PM
MaVeN's Avatar
Default Shift kit?
How does this work?
http://www.700r4l60e.com/store/catalog/TransGo-4L60E-Street-Strip-Shift-Kit-Full-Manual-p-91.html
Old Apr 3, 2011 | 07:23 PM
MelloYello's Avatar
Shift kits for electronic controlled transmissions... nope... they will adapt to the changes and roll with the changes making them useless ..
Old Apr 3, 2011 | 07:34 PM
greenmachine96's Avatar
This is for a a trans that you are tuning to have firmer shifts for racing use I believe. So basically you would have this kit installed and it will allow the trans to perform better under race use after you have it tuned. But this particular kit is probably to be used in a built racing trans. They also have the street/strip one with the corvette servo. TransGo 4L60E Street/Strip Shift Kit 1993-2000 :: General Motors :: TransGo Performance Shift Kits :: Pro-Built Automatics
Old Apr 3, 2011 | 08:13 PM
I assume by full manual it removes the computer control completely. You have to shift thru the gears just like a manual trans but without a clutch.
Old Apr 3, 2011 | 09:20 PM
MaVeN's Avatar
If what gorn thinks it is is true. That would be fun. I've wanted a stick, but the traffic is pretty bad at night
Old Apr 3, 2011 | 09:35 PM
im not sure you understand, you have to shift it for it to shift. you put it in drive and its in drive/4th, every time you slow down you have to downshift, every time you speed up you will have to up shift unless you want to dog it in a gear and thats not real good on a trany.
Old Apr 3, 2011 | 09:37 PM
Failed Devices's Avatar
i wouldn't go with a manual valve body, but a shift kit can work by making shifts firmer.
Old Apr 3, 2011 | 10:25 PM
if your going over 350 hp you will want a few things. servo and sunshell are a couple things that come to mind. theres some good info here Performance Transmissions and Parts from PATC 700R4 AOD 4L80E 48RE
Old Apr 3, 2011 | 11:15 PM
MaVeN's Avatar
Thanks craby
Old Apr 4, 2011 | 03:00 PM
Massey's Avatar
If you are just looking to change the shift points or make the shifts firmer then you only need to have the PCM adjusted (tune) to make that happen. The corvette servo will also help.
Massey
apetsel
Mar 25, 2011 06:27 PM
bigtim1985
Sep 29, 2010 11:28 PM
th3po1son
Jan 20, 2008 08:56 PM
KoRN_Munky
LS Series Tech
Mar 25, 2007 02:49 AM
94Z28SHAKER
Jul 11, 2005 02:38 AM
