Security light on but car running sometimes
A friend has a 2001 3.8 V6. His Security light stays on all the time. Car starts and runs fine but will die within 5-10 minutes. I would lean toward ICM if it were not for the Security light on all the time.
The puzzling part to me is that I have a key for my camaro that has no chip in it and if I try to start the car with that key the car will not even crank over. If I try it two or three times it will not start for 5 minutes even with the right key. I do not understand his car running at all with the security light on.
Any thoughts I have searched and done some reading but have not found this issue.
X2... 18 years of working on just this. Your best bet.. Bypass. take an OHM meter, and test your key.. see what it read's. you'll get something like 1.2k or 850 or 3.2 (3200) and get that value resistor.
go under the dash, find the think orange wire. follow it back before you cut it. make sure you see two white wires coming out from this casing. if you got the right one, youll have two white wires inside this orange thick casing. cut it on the key side... not the fire wall side.. make sure you'll still connected to the block.. put the resistor in line with the white wire. one side of resistor to one white wire, and other side of resistor to the white wire. ( again, both are white.) wrap the wire, and test car. start the car, and see what it is doing. Most cases its the reading part. it gets dirty and can send a close, but not dead nuts reading. so it will **** with you like so. replacing is mucho dollars. this is about 1.00 and it works. after your sure it starts... solder connection, and tape. dont let them touch.
PM me if you need.
PM me if you need.
Thanks Craby. I actually had found that one the day after I originally posted here It would appear his car is running in fault enabled mode. He told me the next day the light had been on for a few months. I swapped his Ignition Control Module for him today since I had a spare laying around from the used engine I bought for mine. We will know in a day or two for sure
if the security system fails while the car is running it will go into fault mode and allow the car to be started even though the proper code is not getting to the computer.
a friend has a 2001 3.8 v6. His security light stays on all the time. Car starts and runs fine but will die within 5-10 minutes. I would lean toward icm if it were not for the security light on all the time.
The puzzling part to me is that i have a key for my camaro that has no chip in it and if i try to start the car with that key the car will not even crank over. If i try it two or three times it will not start for 5 minutes even with the right key. I do not understand his car running at all with the security light on.
Any thoughts i have searched and done some reading but have not found this issue.
x2... 18 years of working on just this. Your best bet.. Bypass. Take an ohm meter, and test your key.. See what it read's. You'll get something like 1.2k or 850 or 3.2 (3200) and get that value resistor.
Go under the dash, find the think orange wire. Follow it back before you cut it. Make sure you see two white wires coming out from this casing. If you got the right one, youll have two white wires inside this orange thick casing. Cut it on the key side... Not the fire wall side.. Make sure you'll still connected to the block.. Put the resistor in line with the white wire. One side of resistor to one white wire, and other side of resistor to the white wire. ( again, both are white.) wrap the wire, and test car. Start the car, and see what it is doing. Most cases its the reading part. It gets dirty and can send a close, but not dead nuts reading. So it will **** with you like so. Replacing is mucho dollars. This is about 1.00 and it works. After your sure it starts... Solder connection, and tape. Dont let them touch.
Pm me if you need.
Pm me if you need.
Well, I had the resistors installed in my 99 and it helped narrow the problem down to the BCM. radio shut off randomly when that would happen the windows would no go down. in order to replace bcm must have key with it or go to dealer it is a one time use part unless you want to try and trouble shoot the right resistor to install.
sometimes you can reflow the solder on the bcm. in the how to and faq sticky at the top of the 4th gen section. here it is https://camaroforums.com/forum/4th-g...-repair-52062/
