LT1/LT4 Tech 1993-1997
security light
Old Apr 21, 2007 | 12:57 AM
yamahar6one's Avatar
Default security light
need some help guys,sold my car to a very good friend about two days ago and the security light comes on,the car still fires up but when you drive anything more then 45-50 it cuts out.New keys?or can I put my scanner on it?its a 93 z28.thanks guys.
Old Apr 24, 2007 | 01:17 AM
Default RE: security light
anybody?
Old Apr 24, 2007 | 01:22 AM
bluovlh8er's Avatar
does the key have a chip in it? if so try the spare set. if it still does it may be the ignition. anyway check with (z28pete) first.
Old Apr 24, 2007 | 05:35 PM
That is strange. The VATS is only supposed to keep the car from being started and not shut down the car while it is in motion, as killing the engine at road speed becomes a safety issue. It is possible that the security module has gone bad, or some wires or cables arevibrating loose.
Does the engine just shut down, or does it die slowly?
Old Apr 26, 2007 | 02:03 AM
yesterday it shut down down on him and now it wont start,I tried the spear set and nothing.I also tried to clean the keys and the ignition.The engine did die slowly,Should I try the shobox trick and jump it or buy a new ignition?Thanks guys
Old Apr 26, 2007 | 01:05 PM
You can try the key bypass trick, but becuse of the way the car is acting, I have a feeling the problem is with the VATS/security module.
Socom
Nov 9, 2013 01:41 PM
canomjm1a1
Jul 11, 2013 04:18 PM
JordanN
Jan 8, 2010 10:17 AM
ranger4620
Apr 30, 2007 02:30 PM
Mr. White
Feb 28, 2006 09:06 PM
