rpm/power problem
Old Jan 22, 2012 | 08:42 PM
tcon11's Avatar
Unhappy rpm/power problem
i have a 98 v6 3.8 camaro and I'm having problem with power and rpms. when I'm in gear my car will only accelerate to 3500 rpms and then no more power will be given to the car, I'm getting the code p0420(catalytic efficiency below threshold) and i don't know if i should replace the cat, or if it would be better not to have a cat at all. or if that is what the problem is?
Old Jan 22, 2012 | 08:51 PM
BasicConcepts's Avatar
Technical User
if i were you id pull the front o2s and see if the problem goes away (this will test weather the cat is clogged or not) if it gets better replace the cat... if not you have an o2 problem
Old Jan 24, 2012 | 05:43 PM
tcon11's Avatar
Post
took it to an auto care place and they said it was the cat so they took it out and it runs great now, thanks for the help.
Old Jan 24, 2012 | 06:15 PM
wow,,, not easy to find a shop that will take a cat out and not require you to replace it.
rockinroller
Sep 19, 2009 10:08 AM
Tar Heel
Aug 21, 2009 03:55 PM
Shifty
Feb 19, 2006 04:20 PM
HotRod53
Apr 22, 2005 01:14 AM
