reprogramming a new transmitter help
Old Dec 24, 2009 | 05:04 PM
doinnslow's Avatar
Default reprogramming a new transmitter help
ok i got a transmitter and it had the stock alarm on it and read that you can use a jump wire to connect a/g in the dlc but in the dlc it doesnt have A any other way of doing it 93 lt1
Old Dec 24, 2009 | 06:37 PM
josh95camaro's Avatar
Look for the piece you plug a programmer in under the steering column ( it should be under and to the right, the DLC) and count over from the the upper left, left to right to number 4 and number 8. Put a wire between those two and then hit your keyless entry and it should lock and unlock your doors. Waa laa you're done!
Hiro
Apr 30, 2012 02:28 PM
Sniper
Jul 10, 2009 03:13 PM
KawasakiJ14
Jun 28, 2009 03:39 PM
akohnz
Apr 23, 2006 08:18 PM
