Replacing a water pump on LT1
Old 06-06-2017, 11:06 AM
Novo's Avatar
So these two small yellow (yellow like on that picrture from Impala SS LT1) o-rings only do - anti-vibration function for the metal coupler from its two sides - water pump side and engine side? Am I right?
And the seal with metal part - is exact that seal that must be replaced using special tool? I will think twice before changing it. Will inspect for oil leaks.
Another one question. What size of the water pump bolts? Is that size in inch or cm?
Old 06-06-2017, 11:28 AM
lol, its sorta hit and miss on these cars, some bolts are metric some are standard, can get frustrating.
Old 06-06-2017, 11:35 AM
95 camaro 406's Avatar
if replaceing the water pump.?? ok you talked about it do it now .you should replace the opti spark to an do wires an plugs as the pump has to come out, to do a distrbutor on an lt1 engine the opti spark is right under the water pump , welcome good luck too
98chevcamaro
01-20-2009 08:19 PM
jordanrinek
10-12-2008 01:56 PM
M.$tErNeR
09-02-2008 11:03 AM
gearyr
05-24-2007 08:47 AM
Quick Reply: Replacing a water pump on LT1
