replacing the water pump
Old Aug 11, 2008 | 12:55 AM
M.$tErNeR's Avatar
Default replacing the water pump
anyone have any advice or know around how long this takes to do.thanx
Old Aug 11, 2008 | 08:54 AM
95LT1.'s Avatar
Default RE: replacing the water pump
I did my 97 LT1 in about 2-3 hours. I had to remove the fans, radiator, and it is pretty simple from there. Remember there are 6 bolts not 4 like later GM water pumps.
Old Aug 11, 2008 | 11:30 AM
meteoralp45's Avatar
yeah, like he said, remove the fans first, and theres a hiddin bolt behind the AIR system
Old Aug 11, 2008 | 11:31 AM
so you have to remove that. and also be verrrrrry careful when actually taking the water pump off cause there are some o rings and a bearing on the camshaft, that if you damage will leak oil
Old Aug 11, 2008 | 06:06 PM
noz's Avatar
noz
i agree ive done it before it took me 2.5 hours a was my first time and i messed up some orings be very carefull .
Old Aug 12, 2008 | 01:39 AM
95slvrZ28's Avatar
Psst...guys, LT1 advice for an LS1 car isn't going to go very far[8D]
Most of the advice will probalby still stand, but you may be looking at different times. I've never done a water pump on an LSX...
Old Aug 28, 2008 | 10:43 PM
QC97Z's Avatar
Again, an LT1 comment...
It took me about 3 hours to do, with a couple short breaks to clean up, and a break to eat pizza.
What's with you guys and your crazy fans/radiator removal? I didn't take any of that stuff out.....
The only things I removed besides the water pump itself were the air pump/bracket and the air intake...
But this doesn't help with your LS1. Sorry.
Old Sep 2, 2008 | 11:03 AM
Nessy's Avatar
Ya, not sure about the LS1, but it took me about 4 hours on the LT1.
cantdrive55
Sep 7, 2013 10:12 PM
BasicConcepts
Aug 14, 2010 08:29 PM
khawkins192002
Feb 8, 2010 01:13 PM
98chevcamaro
Jan 20, 2009 08:19 PM
gearyr
May 24, 2007 08:47 AM
