Replacing LSD Clutches
Old Nov 19, 2011 | 05:25 PM
Chaotic94's Avatar
September 2011 ROTM
Default Replacing LSD Clutches
Hey guys. I recently bought an LSD rear end out of a 1996 6-speed z28. At this point if I brake stand the car, only one wheels spins. I put it on jack stands today and if I spin one tire by hand, the other spins in the same direction while the car is in gear. I put limited slip fluid in it when I bought it. Do I need new clutches? Or???
Any advice is greatly appreciated!
Also note that when I first bought the read end I could spin both tires when I brake stood the car. Now it's a single tire fire
Old Nov 19, 2011 | 06:32 PM
if its cone clutches then they can be rebuilt but only by the factory. and the factory will only rebuild units that are four years old or less.
Old Nov 20, 2011 | 01:39 AM
Chaotic94's Avatar
September 2011 ROTM
So I'm basically screwed...?
Old Nov 20, 2011 | 02:40 AM
You didn't use synthetic gear oil in the rearend did you? And the additive prevents the clutches from gumming up and making the rearend go clunk-clunk-clunk in the turns. It's not a friction enhancer.
Old Nov 20, 2011 | 10:31 AM
Chaotic94's Avatar
September 2011 ROTM
I used valvoline limited slip rear end 80-90 gear oil. Exactly what GM told me to use lol
Old Dec 4, 2011 | 10:15 PM
Chaotic94's Avatar
September 2011 ROTM
I added the additive and it didn't help. Anyone have any advice?
Old Dec 5, 2011 | 09:51 AM
Cheeks's Avatar
August 2011 ROTM
sounds like the center section might just be worn out, time to buy a new center, they aren't too bad
Old Dec 5, 2011 | 10:02 AM
Chaotic94's Avatar
September 2011 ROTM
How hard is it to replace?
Lj2069
Sep 7, 2010 06:24 PM
redreffitt
Apr 4, 2010 11:00 AM
rondavis
Aug 20, 2009 07:29 AM
SpecterGT260
Jun 20, 2008 06:31 PM
Pro_built7
Apr 8, 2007 12:07 AM
