replacing computer
Old Aug 22, 2011 | 03:24 PM
Katzen's Avatar
Default replacing computer
any one know where to get one programmed? i talked to autozone and they said with the different engine that they wouldnt be of help but to go find a place that can flash it..... and theres my problem..... i have no idea where to look for some place that can do that (by the way the computer fried which is why i have to replace it)
Old Aug 22, 2011 | 04:48 PM
Most GM dealers will be happy to reflash you computer back to stock, for a price.
Old Aug 22, 2011 | 06:15 PM
Katzen's Avatar
i figured that but my car is basicly a frankenstien, so would that be a problem?
Old Aug 22, 2011 | 07:28 PM
If the car has been modified extensevely, and you don't know what the actual mods were, then the PCM will need to be tuned with the help of a dyno. If you know exactly what mods were done, then you may be able to get a mail order tune.
It would be a great help in answering your question if you divulged what engine and mods you are hinting to.
Old Aug 22, 2011 | 08:01 PM
Massey's Avatar
THe computer for the 98 has alot of tuning options and a Dyno shop can hook you up there. THe 92 is a totally different story and a totally different method for programing. Usually with the 92 you need to send the main PROM chip in to be "flashed" using special equipment that is becomming hard to find.
Which car is in need of the tune and what have you done to it. Oh and the 3800 does not like to run with out a thermostat, it will keep throwing you a coolant too log code and put the engine in reduced power mode or limp home mode if it does not get to 210 like it likes. The 92 prolly does not care but will run better if it can get hot faster.
Massey
Old Aug 24, 2011 | 04:30 PM
Katzen's Avatar
theres no mods to it just parts from every other camaro like, the engine is from a 96, and all of the parts i needed for the 96 engine were from the 95 engine that was in it when i got it (by the way why are we talking about thermostats and my 92????)
Old Aug 24, 2011 | 08:15 PM
Massey's Avatar
Talking about the T-stats in both.
Massey
Old Aug 24, 2011 | 10:16 PM
jrgearhead's Avatar
LT1 PCM Tuning - Welcome! All kinds of great reviews from Solomen on this forum including me. so send him a email and see what he can do for you.
Old Aug 25, 2011 | 07:48 AM
Katzen's Avatar
the 98 has its thermostat massey, the 92 doesnt because the car was overheating really badly with it in....
but anyways, let me restate this, i have to put a new computer in the 98, my engine is from a 96, does it matter if i when get the computer flashed? and where can i get it flashed (besides dealer)
Old Aug 25, 2011 | 01:21 PM
jrgearhead's Avatar
I believe you should just get the computer flashed as if it was in a 96 and you will be fine
