removing my motor...quick question
Remove the lines from the antilock brake unit. and I removed the trans X-member from the car and let the trans hang with no ill effects. Just be careful lowering the engine it is heavy and will want to fall kinda fast.
Massey
Massey
i let the motor rest on my cart and i'm pulling the frame up not dropping the motor down. ok but i have to figure something out because all the nuts at my abs unit are stripped.....i also just ran into another problem where do you remove the main wire harness? dont tell me i have to disconnect them from each of my injectors and so on
Remove it from the computer and all other connections outside the engine and lay it over the top of the engine.
See here
![Name: 0721101605.jpg
Size: 110.6 KB](https://camaroforums.com/forum/attachments/93-02-general-41/28053d1501309481-removing-my-motor-quick-question-0721101605.jpg)
At this point I am just bout ready to lower the engine, all connections are disconnected all I have left is to remove the hard points and lower the engine.
![Name: 0721102149.jpg
Size: 40.3 KB](https://camaroforums.com/forum/attachments/93-02-general-41/28054d1501309481-removing-my-motor-quick-question-0721102149.jpg)
Sorry for the crappy photos I only had a cell camera at the time.
Massey
See here
Massey
ok i believe my problem was the intake manifold gasket however i figure i change the head gaskets while the motor is out. on the tip of the block where the piston reaches its peak it looks like there is minor chipping (around the tip of the circle where it looks like theres another circle in the block). is that natural? and is there anything else i should change while i got this far
TO me it sounds like he is talking about the little ridge that the piston rings leave at the top of the bores. If so that is normal. It is left there because the rings dont reach up that far to scrape the residue from the fuel burning off.
Massey
Massey
yeah i figured that i tried to upload photos but my phone wont send them for some reason. the push rods have no order when i put them back in because when i took the heads off they fell everywhere. also how would you clean the top of the pistons because they are dirty
