Rear gears?
Old Sep 29, 2011 | 07:45 PM
MaVeN's Avatar
Default Rear gears?
Getting 3.73s for my auto. Are these my best bet?
http://www.hawksthirdgenparts.com/camarofirebird82-2002newmotivegearsgm75and7625ringandpinionset.aspx
Old Sep 29, 2011 | 09:34 PM
It all depends on what you are trying to accomplish.
Old Sep 30, 2011 | 12:02 AM
MaVeN's Avatar
Trying to get my car to keep up with stock/lightly modded ls1's. Basically a 12.7-12.9 car without going internal while still being a dd. I've posted on ls1 tech and they said it should be possible.
Old Sep 30, 2011 | 12:21 AM
Buffalo02Z28's Avatar
I would try to get used rear gears. Check LS1 Tech's parts classifieds.
Old Sep 30, 2011 | 01:57 PM
Failed Devices's Avatar
Stall > Gears for an auto
Old Sep 30, 2011 | 03:17 PM
MaVeN's Avatar
I'm doing both at the same time. ^
Old Sep 30, 2011 | 04:14 PM
If you are really looking for low ETs you need to go lower than 3.73, more like 4.11 or 4.56. You want the engine to hit the red line as you cross the finish line. However, this will make driving at highway speed a buzzing experience, but it will be a hoot around town. Wheel spin off the line could be a problem, but a set of drag radials and stiff rear shocks will help a lot.
The 3.73 make a good all around compromise, but not the best for drag racing.
Old Sep 30, 2011 | 06:27 PM
3800camaro's Avatar
3.73 for auto is pretty good. Soft rear shocks will allow weight transfer to the rear nicer to help prevent wheel spin. I have 4.10s on my 3.8 with the 5 speed and you sure notice the difference. Haven't hit the 1/4 mile yet tho.
Old Oct 8, 2011 | 07:36 PM
99 SS's Avatar
I agree. If you're looking for low ETs, go with 4.11 or 4.56. If you want to keep it reasonable on the street though, go with 3.73. I had a 97' TA that I had 3.23's in, and I swapped them out with 3.73's, and it was a very noticeable difference, yet still decent for the street with normal highway driving.
May 25, 2011 02:05 PM
Chance_Logan
Feb 21, 2010 11:29 PM
daltons 1980
Nov 9, 2007 12:01 PM
1985RS
Jul 8, 2007 11:04 PM
gozzy341
Feb 15, 2007 10:28 PM
