Pulsating/Pop sensation while at idle
Old May 20, 2016 | 12:52 PM
  #41
i tested mine by clamping off the return line. risky way to do it though, plastic line will crack if your not careful
Old May 23, 2016 | 09:46 AM
  #42
rs657f's Avatar
I took a break from some troubleshooting this weekend. The line from the FPR to the side of the intake is still in tact. I ordered a new pump, some o rings and FPR which should be in this week. I want to test the FPR since we discussed the pressure dropping rapidly. Maybe its stuck open. Since the line on there now is plastic and prevents me from doing the pinch test. Can i toss a rubber vacuum line on there with some worm clamps and try the pinch test without any kind of repercussions?
Old May 23, 2016 | 10:21 AM
  #43
i slid up the cover to get to plastic that hasnt seen the uv rays. then used folded over cardboard over the line to protect it. then clamped it with vice grips but not to hard.
Old May 24, 2016 | 05:38 PM
  #44
rs657f's Avatar
Hey Craby guess what I found? My 7 cylinder injector is leaking bad when i turn the key to the on--engine off position. Im guessing that is why my pressure is dropping and car sucks at starting. Im assuming i need to replace the injector? If so im looking at some refurbished 24# denso injectors. Thoughts?
Old May 24, 2016 | 07:52 PM
  #45
got mine used from an injector shop, checked out, cleaned, flow tested and flow matched. you might be better off getting another set, if one of yours is failing then it may be that more will need rebuilt. thats what costs. if they can get them and just clean and test its not that much cost.
Old May 24, 2016 | 08:26 PM
  #46
rs657f's Avatar
good deal ill reach out to some shops and see what i can find...
Old May 25, 2016 | 08:27 AM
  #47
sniff your oil, if it smells of gas change it. the overload of fuel will drain down past cylinder rings and get in the oil.
Old May 27, 2016 | 07:34 AM
  #48
rs657f's Avatar
yea I know and I literally changed my oil a few days before all of this happened
Old Jun 1, 2016 | 03:08 PM
  #49
rs657f's Avatar
FML right now. I was removing my fuel injectors and an o ring fell off and went down into the intake manifold. Not sure if i should remove the intake or what? I was reading that they usually melt and blow out the rear but i dont trust that too much. Any thoughts? I tried fishing it out but i got nothing
Old Jun 1, 2016 | 04:57 PM
  #50
might try a bore scope 2 5 10M 6LED USB Waterproof Endoscope Borescope Snake Inspection Camera 5 5mm | eBay maybe call local parts stores and see if they have any for rent of borrow, woh,,, you got post 19000
