Pulsating/Pop sensation while at idle
nearly as bad as it was before the 02 change. I get a slight stumble at low rpms usually when i take
off after a red light and while cruising but at high rpms it runs like a champ. Ill have to just keep probing at it for the time being
I appreciate the patience with the lengthy thread
So i finally was able to hook up my 95 scanner, i didnt get any DTC codes but i have some codes showing up under electrical faults tab. My Fan 1 low and Fan 2 high relay are open. EGR solenoid open ,TCC (transmission) solenoid is open, VAP purge CCP is open and VSS open. I am assuming one of those is causing the misfire and stumbling. I will pull the EGR off this weekend and see if its creating suction but other than that im pretty lost.
ok so screw me. I was attempting to replace the evap solenoid and somehow ended up having to remove my intake, heres how that happened lol. The evap is so far under the fuel rail i couldnt get a socket on the bolt to remove it so i took the fuel rail off and noticed 5 out of 8 injector pintel caps fell off into the chamber again. Good thing i removed the rail and caught this. No wonder that nasty stumble popped back up again. So to wrap this up my question is can i put some kind of heat resistent super glue on the top of the cap to keep it on the injectors? I pushed them on hard and heard the click so i thought they wouldve stayed in place. I figure they have some kind of function so id rather not have them off the injectors.
The caps on the end of the injector near the spray needle.
Set of 8 New Fuel Injector Pintle Caps Bosch or Denso EV1 Mustang Ford 5 0L | eBay
