problem with 97 camaro
Old 11-24-2010, 12:41 PM
PO147 indicates the heater circuit on the O2 sensor is bad, Could be wiring or the sensor itself.
  #22
Old 11-24-2010, 12:57 PM
ChevyManCam's Avatar
i just replcaed the cat it was the problem, i have all my power however the car is idling at 2k now and engine light still stays on, also a scanner wont read the ecu anymore, under the hood the fuse for ecu if i put a fuse in it the car wont run any help please we almost have this car fixed
  #23
Old 11-24-2010, 01:15 PM
update just found a black top piece of the maf stuck in the tb where the maf sits, it was broke off the maf
  #24
Old 11-24-2010, 01:23 PM
BasicConcepts's Avatar
Technical User
that could be a problem
  #25
Old 11-24-2010, 03:59 PM
car is still idling high, and check engine light wont go away. failed a smog test because it says the mass or volume air flow circuit has a low input, but i already changed the mass air flow
  #26
Old 11-24-2010, 04:07 PM
codes are P0102 AND P0507, after replacing the cat, and the check engine light will not go away, still high idle. already replaced MAF WHAT ELSE CAN THIS BE!!!!
  #27
Old 11-24-2010, 08:21 PM
ok guys whos got a trouble shooting chart for po102 and po507. try searching. do you have a k&n filter? is the maf remanufactured?
  #28
Old 11-24-2010, 09:10 PM
the maf is from auto zone, its a cone filter not a k&n, its a spectra
  #29
Old 11-24-2010, 09:34 PM
Chaotic94's Avatar
September 2011 ROTM
I didn't read this whole thread. Just the first post by the OP. So it's stumbling after 3k rpm's. Mine was doing this too for about a month before I did a fuel pressure test. I had a weak fuel pump. Sorry if that's already been covered. I didn't have time to read all the posts in the thread. If you haven't done a pressure test yet, do that next.
  #30
Old 11-24-2010, 09:38 PM
Chaotic94's Avatar
September 2011 ROTM
Disregard what I said about the pressure test. I just read the whole thread. ***Smacks Myself In The Face!!!***
Quick Reply: problem with 97 camaro
