Possible o2 sensor bad?
Old Oct 11, 2014 | 05:08 PM
Mizz88's Avatar
Default Possible o2 sensor bad?
I had my check engine light come on today and using a generic scanner. I came back with these two codes
P0141
P0172
Im assuming it means the o2 sensor is bad, is that correct? if so, which sensor is it?
btw, I have a 97 v6 camaro
Thanks in advance for any help
Old Oct 11, 2014 | 11:32 PM
P0141 = bank 1, sensor 2 (after the cat)
P0141 Chevrolet O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 2 OBDII Engine Light Trouble Code | Engine-Codes.com
P0172 = bank 1 too rich
P0172 Chevrolet Fuel Trim System Rich Bank 1 OBDII Engine Light Trouble Code | Engine-Codes.com
Changing the upstream sensor will probably fix both codes, unless there is a wiring problem.
Old Oct 14, 2014 | 10:49 PM
torque_is_good's Avatar
you might also have an exhaust leak (before the sensors)
fuhhuayt
May 5, 2011 01:04 PM
imcdowel
Jul 26, 2010 11:59 AM
EagleRex
Jul 20, 2010 03:36 PM
Dznuts
Sep 27, 2009 06:48 PM
98sleeper
Nov 1, 2007 01:37 PM
