pasanger side window problem
Old Jan 9, 2011 | 04:51 PM
sebi1990's Avatar
Default pasanger side window problem
My window started to nreak down after i pressed to open it and my gf at the same time now the window rolls down but when i press for it to roll up it goes up a little but after it dose i have to wait about 4-6 minutes to go up another bit what might be causing this?
Old Jan 9, 2011 | 07:47 PM
Chaotic94's Avatar
September 2011 ROTM
Does it seem weak? Is it moving slower than usual? You probably need a new window motor.
Old Jan 9, 2011 | 08:48 PM
osduck5's Avatar
Time for a window motor. If you never replaced one, read the below link first. It includes pics of "how to"
http://shbox.com/page/windowmotor.html
Old Jan 9, 2011 | 08:49 PM
greenmachine96's Avatar
window motor, just happened to mine a month or so ago.
Old Jan 9, 2011 | 11:20 PM
How did you open your window, and your girl friend at the same time? I wanna learn that trick!!
Old Jan 10, 2011 | 12:52 PM
sebi1990's Avatar
on the driver side i press down and she presses up on her side
Old Jan 10, 2011 | 01:25 PM
Chaotic94's Avatar
September 2011 ROTM
Sounds more like a wiring issue than a window motor IMO
Old Jan 10, 2011 | 01:42 PM
torque_is_good's Avatar
hey, I chuckled
Old Jan 10, 2011 | 01:59 PM
Massey's Avatar
Still confused by the GF thing but ok... Now as for the window motor issue:
What is happening is the circuit breaker is being tripped and it takes a few mins to cool off and reset. This happen from a weak motor, binding regulator, binding tracks, or a combo of 2 or more of the issues. Chances if you had any binding then you have already fried the motor and will need to replace it. I recomend paying a little extra and getting the full motor and regulator unit. When you put the stuff back together make sure you grease the tracks again and get them good so the regulator slides through them really smooth.
Massey
Old Jan 10, 2011 | 02:39 PM
Originally Posted by torque_is_good
hey, I chuckled
At least somebody got it. Me thinks my pun (based on his sentence structure) went over his head.
