Optima Battery
Old Oct 7, 2012 | 07:20 AM
Volcente's Avatar
Default Optima Battery
Hi to all!
What Optima Red Top battery I can ilstall on a 1999 chevrolet camaro?
10 inches in length are too many? or are ok?
on the right of battery replacement there is the radiator and an alluminium tube!
Any of you have a optima red or yellow under the hood?
Serial number of this battery?
Many many thanks!
James
Old Oct 7, 2012 | 12:23 PM
MKCoconuts's Avatar
Should be a exact fit. Part # is 75/25-925 for the red top.
Old Oct 8, 2012 | 10:13 PM
i have a yellow top in the 93. barely fits. pain to get out but what a great battery.
Old Oct 9, 2012 | 02:02 PM
Volcente's Avatar
44 amps yellow top?
Because if you have the 50 amps it isn't the correct size battery.
The correct size is the 44 amps...
Old Oct 9, 2012 | 09:57 PM
MKCoconuts's Avatar
Originally Posted by Volcente
44 amps yellow top?
Technically speaking, there is no correct size. What ever you can get that fits and works is the correct size. Just today I had a girl come in with a Isuzu Trooper that had a Marine battery in it. Not my choice of battery, but hey, it worked for the girl for a while!
Old Nov 13, 2012 | 09:03 AM
Volcente's Avatar
I've got the 44 amps red top!
In Italy the serial number is different, because the Optima use a different serial numbers in the different countries, but it is the same 75/25-925 Optima Red Top.
http://www.optima-batterien.eu/uploa...T_U_3_7_en.pdf
It is perfect!
Many thanks to all!
James
libertyforall1776
Feb 24, 2014 02:11 PM
Dana
Dec 20, 2013 02:56 PM
Amy Z28
Feb 22, 2012 02:58 PM
iLL95
Nov 8, 2011 04:04 PM
djs383
Dec 10, 2010 08:17 AM
