oil pressure ?
Old May 5, 2009 | 08:18 AM
jeremy lutren's Avatar
Default oil pressure ?
I just bought a 95 Z28 with 65,000 miles. The car is in very good condition, so it looks like it's ben cared for. My question is what kind of oil pressure should I be running at idle after the engine is up to operating temp?
It drops from about 40 psi to around 20 psi at idle, if I raise the rpms up a little the pressure jumps right up to 35 psi +. Does this sound right for an LT-1?
Old May 5, 2009 | 08:34 AM
niteman's Avatar
when was the last time the oil was changed in it? I know mine gets alot lower near the end of its life. seems kinda low to me.
Old May 5, 2009 | 02:12 PM
73camaroSS's Avatar
when the car warms up and the oil flows better and you dont need 60 psi at idel but as long as it goes back when you raise rpms it shouldnt be a prob.but at least thats how it works in old *** cars like mine.
Old May 5, 2009 | 03:04 PM
6v49der's Avatar
Sounds normal for an LT1. Niteman, it shouldnt matter when your oil was changed, thats not going to affect pressure unless your losing oil. That, and each engines run different pressures, so that would be low for a 3.8 v6, its fine for the LT1.
Old May 5, 2009 | 04:08 PM
niteman's Avatar
so 10k oil has the same viscosity as fresh oil? I change my oil and the pressure is slightly higher and gradually goes down. maybe my car is weird.
Old May 5, 2009 | 04:10 PM
niteman's Avatar
and no... I'm not losing oil... ok... well maybe a half quart between changes.
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
