oil pressure
Old Sep 22, 2007 | 08:40 PM
dagger213's Avatar
Default oil pressure
Hello
im new here so sorry if this has been asked to death already.
I just bought a 1999 Z28 with 66k miles on it. I noticed that when its warmed up and driving downt the freeway, the oil pressure is a little above 40 pounds. When i stop it goes half to three quarters toward 20 pounds and I can see the needle fluctuating back a fourth a bit. I just changed the oil and put mobile one in it. Is this normal or should i be worried.
Thank you
Joe
Old Sep 22, 2007 | 09:41 PM
Default RE: oil pressure
Don't worry about it, relax, that is the way it is supposed to work. That is the reason that most cars don't have oil pressure gages, they make people worry for no reason. LOL
By the way, did you change the oil filter also? Don't make sense to change the oil and keep a dirty filter, so that it can contaminate the new oil.
Old Sep 22, 2007 | 09:45 PM
dagger213's Avatar
Thanks for the reply.
Makes me feel alot better knowing its all working ok.
Joe
Old Oct 2, 2007 | 11:43 AM
chrismorales75's Avatar
If you stop hard and lose pressure you could be low on oil.
Old Nov 5, 2008 | 09:19 AM
mafia_rules's Avatar
Default low oil pressure while breaking
Hi u guys..
i read ur posts and im sure some1 would be able to help me out here..
i got a camaro ss 97 anni edition I have the same problem.. whenever i start my car everything is normal... no warning lights nothing.. and then when im driving around and when i break from a distance to stop at the stop light the oil pressure goes till the end and the check gauges light turns on?? and when the car copmpletely halts at the stop light the gauge goes back to normal and the light is gone.. wat can be the problem? i even got my engine oil and every oil possible changed in my car?.is it the oil sensor?
or is it something else?
what can it be? and just for my information can u even please let me know how much litre oil is supposed to be put in a 5.7ss engine? just to be sure?
so is this something to worry about or is it normal? please some1 reply back asap..
thanks in advance.
Old Nov 18, 2008 | 05:41 PM
QC97Z's Avatar
Default RE: low oil pressure while breaking
Mafia-
It is possible that you're low on oil, or there's an issue with the pickup. Your oil pan is deeper toward the rear of the engine than the front. What happens when you stop is your oil moves toward the front of the engine, and your pickup tube isn't pulling as much oil as it should, thus your oil pressure going down. If it's going down all the way until you get the check gages light, sounds like low oil.
How much oil do you put in it? As much as the owner's manual says, or as much as it takes til the dipstick reads full. Either way will work.
Old Nov 20, 2008 | 06:30 AM
Z28Reggie's Avatar
I have got a 94 z28 with the 5.7 and i put 5 quat.
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
