Oil gauge problem
Old Mar 21, 2008 | 09:46 AM
Jeremy93z28's Avatar
Default Oil gauge problem
Hello im a proud owner of a 93 Z28 which I baby this car......Well recently i've noticed that when I get it below 1000 rpms im guessing around 700 to 600 the gauge will jump well over the 80 mark for a split second. So, im left with a somewhat noobie question should I be worried? The engine isnt making any noise and it seems to run great still. Just wondering if maybe my oil pump may be going out or if its even instrumental problems. Also the car has 104,000 miles on it im running Castrol 10w-30 should I change weight? because of the weather change? If that is an issue.
Old Mar 21, 2008 | 02:16 PM
95slvrZ28's Avatar
Default RE: Oil gauge problem
If it's only at a low RPM I would say you probably don't have too much to worry about. It's possible there is some air bubbles in the line and that's throwing off the sending unit, or the sending unit is going bad.
alho672
Aug 20, 2012 11:33 AM
80z28guy
Apr 4, 2011 11:51 PM
ttowndex
Dec 21, 2010 11:20 PM
cpetersen
Nov 16, 2008 09:43 PM
jhop16
Jan 31, 2007 10:58 PM
