gauge problem
Old Aug 18, 2012 | 07:44 PM
alho672's Avatar
Default gauge problem
li have a 81 z28 camaro with gauges,, not the idiot lights, and i have lost all power to them, they all quit working at once ive replaced all fuses and still can get no power anyone know where the problem may b
Old Aug 18, 2012 | 11:10 PM
moved your thread to the 2nd gen section for yah. one of the guys should be by to help. welcome to the forum.
Old Aug 19, 2012 | 12:04 AM
Check the grounds on the back. Also the printed circuit could have died, it happens but the grounds need to be looked at first.
Heres some help.
#1 Brown - Tach Lead
#2 Green/White - Temp Gauge to Sender
#3 Pink - 12volts switched from #8
#4 Tan/Black - Fuel Level Gauge to Sender
#5 Gray - Dash/Gauge Lights
#6 Black - Ground
#7 Tan - Emergency Brake Light
#8 Pink (2) - 12volts switched - looped to #3
#9 Light Blue - Left Signal Light
#10 Light Green High Beam Light
#11 Blue - Right Signal Light
#12 Blue/White - Oil Light to Sender
Old Aug 19, 2012 | 06:38 AM
Edwardgp's Avatar
That's some great information 77nomad.
Old Aug 19, 2012 | 11:57 AM
alho672's Avatar
i have ground on my harness but i have no power on the connector what so ever, any ideas
Old Aug 19, 2012 | 11:59 AM
Track the wire back. If the fuse is in the wire should be hot unless there is a break in it.
Old Aug 19, 2012 | 12:05 PM
alho672's Avatar
ok, thanks
Old Aug 19, 2012 | 12:10 PM
alho672's Avatar
whats the odds of my keyswitch being bad, the car still starts and runs and everything works though
Old Aug 20, 2012 | 11:33 AM
If you are checking power to the harness plug with the key on and it's not hot, then check the fuses to see if they are all hot with the key on. If neither is hot you need to start following wires until you find the problem. Also check the ground to a known ground to be sure it's not broken.
80z28guy
Apr 4, 2011 11:51 PM
ttowndex
Dec 21, 2010 11:20 PM
cpetersen
Nov 16, 2008 09:43 PM
Jeremy93z28
Mar 21, 2008 02:16 PM
jhop16
Jan 31, 2007 10:58 PM
