I have an 01 camaro with a bad gas sending unit. How hard is it to replace? How long does it take? What do I have to do to change it? Thanks in advance for your help.
BAH HA HA! If it were only that easy..... You have to drop the whole rear axel/ suspensionand then drop the fuel tank. Oryou can cheat and cut a hole in the car above the sender assembly. If you search you will find measurments of where to cut.
