Oil dipstick help.. New here
#32
did you check out the link i gave you. if you click the different colored words there is more info there. one is on the top of the thermostate cover, one is at the bottom of the throttle body and one on the hose. like i said the hose will not bleed till the car is running. after losening the screw a couple turns, (all thats needed) you should see coolant coming out of the base of the screw where theres a small hole. once coolant comes out close it. that site in the link is a great site for info, check it out. gota go be back latter.
http://shbox.com/1/4th_gen_tech1.html
#33
yes thanks for the link and your help.. i only have two bleed screws and bled them, temp seems to be normal now and didnt overheat but then i realized i need another new thermostat since the lt1 takes a different kind. or will the one i have work for now? i also still need to get the fan fixed. does anybody have a part number for them?
#36
if you put a non lt1 thermo in it yes it needs to be changed. the standard small block chev one is not for a reverse flow system. i thought you got a 160 degree lt1 thermo, what one do you have. part number?
