oil change
Old Jan 22, 2011 | 12:07 PM
chsxfireems's Avatar
Originally Posted by Buffalo02Z28
I'm running Motorcraft 5W-30 in my Camaro right now. Good stuff.
Still using that Motorcraft filter too?
Old Jan 22, 2011 | 01:21 PM
Buffalo02Z28's Avatar
Yes I am.
Old Jan 22, 2011 | 06:09 PM
Nope. Definitely not. I've taken a look at their marketing materials (aside from the fact that their API ratings are still not up to current, as previously stated.) and examined the photographs they took of bearing surfaces. Initial bearing surface is rough under extreme magnification. Next photograph is of the same bearing after using a competing oil, surface show's some smoothing (a sign of wear) but still has some rough texture. Final image is of the bearing after using royal purple... the bearing surface is completely smooth (indicating severe wear).
So no, its not good oil.
That's a good point about the bearing surface. What's in their oil that makes the bearing look like it's been sanded down smooth? I wonder if they really realize what they are saying there, because the results they show are actually bad. Here's a link to it: http://www.royalpurple.com/rp-perfor...dvantages.html
Old Jan 23, 2011 | 09:03 AM
There's probably nothing in the oil causing that, just bad lubricating properties.
EightySixCamaro
Apr 2, 2010 05:00 PM
LHill00Z28
Oct 3, 2009 12:36 AM
The Banks
Dec 11, 2008 12:24 AM
Deagle85
LS Series Tech
May 1, 2007 08:55 PM
