OBD2 codes for 2000 camaro z28
Old Apr 28, 2012 | 09:44 PM
rafael707's Avatar
Default OBD2 codes for 2000 camaro z28
hello all, I just bought this 2000 M6 z28 and I have a few codes (not CEL codes) that i pulled up with my friends OBD2 reader made by CENTECH, i would like to know if ANY of these readings look out of the ordinary. The person i bought the car from told me that everything is pretty much stock, except for the flowmasters.
these readings are when the car is off, on accessory mode
DTC_CNT: 0
FUELSYS1: CL
FUELSYS2: CL
LOAD_PCT: 0.0
ETC: 198
SHRTFT1: 0.0
LONGFT1: 7.0
SHRTFT2: 0.0
LONGFT2: 9.4
MAP: 30.1
RPM:0
VSS: 0
SPARK ADV: 0
IAT: 0.000
TP: 0.0
AIR_STAT: OFF
02B1S1: 0.045
SHRTFTB1S1: 0.0
02B1S2: 0.025
02B2S1: 0.015
I even got codes from when the car is on in neutral position
DTC_CNT: 0
FUELSYS1: CL
FUELSYS2: CL
LOAD_PCT: 2.0
ETC: 188
SHRTFT1: 2.3 - 3.1
LONGFT1: 10.2
SHRTFT2: 0.0 - 3.1
LONGFT2: 14.1
MAP: 8.9
RPM: 811
VSS: 0
SPARK ADV: 21-23
IAT: 133
MAF: 0.746 - 0.762
TP: 0.0
AIR_STAT: OFF
02B1S1: 0.065 - 0.800
SHRTFTB1S1: -0.6 ~ -3.1
02B2S2: 0.095
I also got readings from the bank sensor's
02 BANK 1 SENSOR 1
(rich-lean threshd)
MOD: $10
MEAS: 0.365
(LOW FOR SWITCH)
MEAS: 0.300
(HIGH FOR SWITCH)
MEAS: 0.600
(RICH-LEAN SWITCH)
MEAS: 0.040
MIN: 0.000
MAX: 0.248
(LEAN-RICH SWITCH)
MEAS: 0.024
MIN: 0.000
MAX: 0.152
02 BANK 2 SENSOR 1
(rich-lean threshd)
MOD: $10
MEAS: 0.365
(LOW FOR SWITCH)
MEAS: 0.300
(HIGH FOR SWITCH)
MEAS: 0.600
(RICH-LEAN SWITCH)
MEAS: 0.052
MIN: 0.000
MAX: 0.248
(LEAN-RICH SWITCH)
MEAS: 0.032
MIN: 0.000
MAX: 0.184
please anyone who knows the specifications for these codes shoot me in the right direction, thanks and god bless
Old Apr 28, 2012 | 10:44 PM
BasicConcepts's Avatar
Technical User
Those arnt codes there readouts of what the sensors and ignition is doing for example you see the spark avd is at 0 when not running but 21-23 when running meaning the computer as advancing the spark 21-23 degrees before top dead center, as for the rest I really don't know how to read it that well.
Old Apr 28, 2012 | 11:38 PM
dtc cnt is diagnostic trouble code count and yours is 0 so you dont have any codes.
Old Apr 29, 2012 | 02:13 AM
rafael707's Avatar
thanks for the input
Old Apr 29, 2012 | 02:15 AM
rafael707's Avatar
i had a vacuum leak, from a hose that connects to the intake manifold, which gave me 7 error codes
-p0171
-p0174
-p0122
-p0300
-p0410
-p0102
i changed the hose, reset the codes with the OBD2 scanner, and havent got any CEL lights since. thanks for the reply
Bigvs_Richardvs
Jan 3, 2015 12:18 PM
AmericanMuscle1989
Sep 16, 2013 10:33 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
