O2 sensor fix i think???
if its a upsteem 02 sensor it would be tough to use a simulator, the computer needs them to monitor the air fuel ratio. im sorta at a loss here, check wires to 02's for any damage. you could test the evap system and make sure its not failing, check for plugged cat, what is the code that came up? letters and numbers.
fuhhuayt
05-05-2011 01:04 PM
