is this normal?
Old Jan 24, 2011 | 08:32 PM
sebi1990's Avatar
Old Jan 24, 2011 | 09:19 PM
osduck5's Avatar
I assume you are asking about the oil pressure! Yes. the oil pressure will vary with engine speed and engine temps. Don't look like you have anything to worry about.
Old Jan 25, 2011 | 12:02 AM
Massey's Avatar
THe oil gauge is normal mine does just that. What is the CEL on for? What are the codes.
Massey
Old Jan 25, 2011 | 12:39 AM
sebi1990's Avatar
Cel is on for random missfire it hapens everu time i go above 4 k rps it i think its the ignition coil damn 300 code btw any1 knows a good deal on a good ignition coil/s either a set or singles?
Old Jan 25, 2011 | 10:03 AM
Massey's Avatar
P0300 is hardly ever caused by the coils!! That code is usually fuel delivery, or a problem with the intake or exhaust. Look into some quality injector cleaner like the Lucas Fuel System Cleaner. Get the big bottle (32oz) and put in about 4 oz every tank till the bottle is gone and see if that helps. Also replace the fuel filter and if you have not done so already have your fuel pressure tested, Low fuel pressure can cause missfires as well.
Massey
Old Jan 25, 2011 | 12:26 PM
MaVeN's Avatar
Mine drops almost by the red.
Old Jan 25, 2011 | 02:33 PM
sebi1990's Avatar
haha that can't be good
Old Jan 26, 2011 | 03:53 PM
frankzlt1's Avatar
mine does that too, it gos to about 1/4 way up when car is warm at idle and as rpms go up it gos up to a little past 1/2 way.
DarlingReject
Jul 15, 2010 11:24 AM
terrychamp01
Aug 4, 2008 03:16 PM
tipdrip215
Jun 30, 2008 11:01 AM
95sport
Dec 29, 2007 11:12 PM
chrismorales75
Sep 19, 2007 11:17 PM
