Not sure if this is normal or not
Old Jul 5, 2010 | 04:27 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
Default Not sure if this is normal or not
I noticed the other week when I was working on Sofie that the passenger side door wouldn't unlock with the key. Since the battery is disconnected and I usually use a key fob, I had to manually unlock my doors to get inside. The key unlocks the driver side and the trunk just fine. But I thought it was a little odd it wouldn't unlock the passenger side. I tried moving it back and fourth, but I didn't want to put too much pressure on it and risk breaking the key off. It unlocks with the key fob and sliding the lock open from the inside, but I would have thought the key would open it from the outside, too. Any ideas?
Old Jul 5, 2010 | 04:49 PM
libertyforall1776's Avatar
The lock mechanism is probably seized up -- spray in some WD-40 to start.
Old Jul 5, 2010 | 04:57 PM
September 2010 ROTM
K. I looked inside as I was trying to turn the key. The mechanism inside wiggles a little, as does the key from the outside, but it doesn't unlock. I wasn't sure if maybe the lock was replaced and the key doesn't work or if the lock itself was probably broken somehow. Anything is possible with this car...
Old Jul 5, 2010 | 05:32 PM
could be the door has been changed and they didnt change the lock. when you get time and bucks have a locksmith check it out.
Old Jul 5, 2010 | 05:38 PM
September 2010 ROTM
That's what it seems like. I know the car has been beat up and possibly wrecked. I just wasn't sure if that was some weird Camaro thing or what. I really never had a reason to manually unlock the passenger side. No one really ever drives with me. But it will be a long time before I can get someone to look at it if that's the case...
Old Jul 5, 2010 | 09:09 PM
traumadog's Avatar
My driver's keylock is also seized. Since I've got the remotes and the passenger side, I let it be.
Old Jul 5, 2010 | 11:13 PM
Not using it leads to corrosion and eventually the tumblers and linkages can freeze up, it's not uncommon at all. Spray inside the lock with penetrating oil as mentioned (I prefer PB Blaster). Give the connected linkages inside the door a shot too, you should be able to reach the spray hose between the glass and the end weatherstripping. Also lube the lever mechanism on the door latch where the rod from the lock connects. Basically, spray everything, let it soak, and then start to work at the lock.
Old Jul 14, 2010 | 06:22 PM
superjatt's Avatar
spray some dub dee for tay. in it . it happens to much truck all the time.
Old Jul 15, 2010 | 11:24 AM
1986CamaroZ28's Avatar
Yeah it could be that the mechanism is locked up or a different door. Try spraying a lubricant into it as Camaro 69 suggested and see if that works if not talk to a locksmith.
im not sure if doors have vins but if they do check that as well
sebi1990
Jan 26, 2011 03:53 PM
terrychamp01
Aug 4, 2008 03:16 PM
tipdrip215
Jun 30, 2008 11:01 AM
95sport
Dec 29, 2007 11:12 PM
chrismorales75
Sep 19, 2007 11:17 PM
