newbee here.ANOTHER fuel pump access door
Old Jun 8, 2010 | 08:13 PM
coopdc78's Avatar
Default newbee here.ANOTHER fuel pump access door
I know it has been gone over a million time, i assume. But im buying a 98z28 with a 2002 ls1 in it. The fuel pump is bad, and i am going to replace it, but the car is 3 hours away... I have searched for the EXACT location so i can cut in the access door..so this is what i came up with.. Basically it is in the middle under the rear seats,... and that s all i got, that and the hole should be 12inches by 8 inches. Any more info that i should know about, as i want this to go as smoothly as possible
Old Jun 8, 2010 | 08:32 PM
Old Jun 9, 2010 | 12:43 PM
And if one of those steel lines is the high pressure supply and you have to cut it, you'll need to flare both of the cut ends and connect it back together with a fitting.
Splicing the supply line together with rubber hose is half-assing it, and can be a recipe for a leak and a "boom".
DashingDaryl
Mar 12, 2012 09:41 PM
HYDRA_SH0CK
Aug 13, 2010 12:32 AM
bluovlh8er
Nov 15, 2007 05:27 PM
libertyforall1776
Oct 17, 2007 12:22 AM
