New member new car
Old Sep 30, 2018 | 04:18 PM
revival11's Avatar
Default New member new car
On my 1997 Z28 I have a OB2 P0785 Shift timing solenoid code. The car starts in 3rd or overdrive. It won't start in 1st or 2nd. I can shift by hand through all 4 with no problem. No slipping or anything else. I changed the 2 A and B solenoids which I got at AutoZone. I still have the shifting problem and the code. I've cleared the code twice but it comes back in 1 second. Can anyone help?
Thanks in Advance
Old Oct 1, 2018 | 08:47 PM
You will need a manual and a volt meter, Remember the computer code is not a error for a single part its an error for the whole circuit. The PCM has no idea if the issue is in the part or the wiring. Heck it could be a problem inside the PCM itself. If you start testing odds are you are going to find a broken or shorted wire.
MrTacticity
12
Nov 20, 2018 10:20 AM
revival11
Sep 30, 2018 03:05 PM
Adam9066
May 15, 2011 12:29 AM
hoursetraitor
Mar 27, 2011 05:07 PM
cavok2992
Nov 15, 2009 11:54 AM
