new battery stalls car
Old Jul 21, 2010 | 09:06 PM
BasicConcepts's Avatar
Technical User
Default new battery stalls car
ok today i noticed i need a new battery i have one lying around new but dead so i popstarted my car so i can charge the new battery (btw now the abs inop and brake lighty are on) and when i went to put the new battery in it stalled my car
Old Jul 21, 2010 | 09:23 PM
I be cornfoosed. "when i went to put the new battery in it stalled my car". Was this battery swap being done while the engine was running?
You have a new but dead battery lying around. How long ago was it new?
Old Jul 21, 2010 | 09:24 PM
Imtbeaar69's Avatar
More then likely that batter needs to have a deep charge put on it so its not geting enough power thru the system
Old Jul 21, 2010 | 09:25 PM
Technical User
yes installed it when it was running but it didnt stall for like 3 min and the batt was new about 5 mths ago
Old Jul 21, 2010 | 09:30 PM
Oops! Does the car not run now? Battery cranks it over, but no fire? Or is the battery still dead?
Old Jul 21, 2010 | 09:34 PM
Technical User
no it will still start i popped it again after i should have just popped it with the new battery in i thought about that after i started it and im popping it alone
Old Jul 21, 2010 | 09:47 PM
Explain "popping". Y'all are using a different term than us Yanks are accustomed to. So it's ok then? Btw, it's not a good idea to run the engine without having a battery connected.
Too many electronics in the car where a voltage spike could fry something. Electrical charges and shorts generally aim for the most expensive part first!
Old Jul 21, 2010 | 11:25 PM
you may have burned the alternator up. you can fry the voltage regulator unhooking the battery when the motors running. a alternator will not run a car on a completely dead battery, unlike a generator the alternator needs to have a small amount of volts to to charge. im surprised it didnt die right away. so charge the battery up and test the alternator.
Old Jul 22, 2010 | 10:41 AM
Charge the battery till it pops, or use the charged battery to pop the alternator? I had a battery pop once & it went on fire. I am sooo confused... However; changing batteries while the engine is running has to be a tar heel thing, maybe too much beer on a hot day.
Old Jul 22, 2010 | 12:31 PM
1stindoor's Avatar
That's North Carolina (Tar Heel) and no...we wouldn't change batteries while it's running.
