Need new hinges?
Old Apr 10, 2010 | 06:42 PM
luciora's Avatar
Default Need new hinges?
Okay so my drivers side door creaks really badly when I open and shut it. I'm not sure if I need to just grease it or actually replace the hinge itself. Here's a picture. Oh and if it needs to be replaced is it a simple bolt on a new one, and is the hinge itself pretty cheap?
Old Apr 10, 2010 | 07:53 PM
Vandee's Avatar
just spray it down with some lube see if the creak goes away. but that hinge does look a little warped
Old Apr 10, 2010 | 08:36 PM
luciora's Avatar
What do you suggest? WD-40 or something a little thicker like white lithium grease?
Old Apr 10, 2010 | 08:37 PM
u may only need a new pin. if u need to change the hinge assembly mark the position on the door and the body so u can get them in the same spot easier. then it u should be able to unbolt and change.
Old Apr 10, 2010 | 08:39 PM
wd will dry it out use lithium or grease. i used the spray lithium stuff and it seems to be working.
Old Apr 10, 2010 | 09:05 PM
luciora's Avatar
Awesome. Thanks guys.
Old Apr 12, 2010 | 12:16 AM
That roller looks pretty well reamed out, and would be the source of your creak. Are your hinges bolted to the door? I remember on my 3rd gen, the hinges were welded to the doors from the factory. You might be better off doing something like this: Door Hinge Roller Kit
Old Apr 12, 2010 | 01:46 AM
luciora's Avatar
Awesome! Thanks, I'll definitely pick one of those up.
NJZ28
Jun 12, 2011 01:13 AM
67Harbor
Jun 22, 2010 11:51 PM
sunfire
Apr 22, 2010 07:30 PM
edogg
Oct 27, 2009 11:18 PM
mortichai
Mar 16, 2006 09:04 AM
