Need electrical help
Old Nov 9, 2013 | 05:57 PM
Xavier Barksdale's Avatar
Default Need electrical help
I have a 95 3.4 5 speed and my injectors aren't pulsing so I disconnect the injector harness from the main harness so I just have the one big plug ok so I tested my driver side bank with 12volts from the two pink wires from the fuses and one fuse was gettin no volts when I tested each injector driver wire on the same side of the harness then I checked the other pink wire and I was gettin a ground from it and I ran a new wire and I still have no injector pulse my cam signal doesn't even fluctuate and ideas the car has been down for five months
Old Nov 10, 2013 | 08:11 AM
Everett#2390's Avatar
On the injector plug, one side is relay controlled battery voltage. The other wire goes to the PCM.
When inj is not commanded open, battery voltage goes to the PCM.
When inj is commanded to open, PCM places a low onto it, but not ground, from its quad driver.
This difference in voltage opens the inj.
The PCM splits the crank sensor signal for ignition timing/spark and also for injector commanding.
Old Nov 10, 2013 | 12:12 PM
Ok but at the connector pictures to took it apart and tested the power wires and one was grounding when I tested it on the injector wires on the same side but the other ones wasn't
Old Nov 15, 2013 | 08:52 AM
have a look here some info that may help https://camaroforums.com/forum/93-02...18/#post618955
Chaotic94
Aug 1, 2012 04:24 PM
bigreed91
Jun 22, 2011 08:39 PM
getsum
May 11, 2009 07:24 PM
CamarocalledKit
Aug 8, 2007 06:22 PM
microkid
Dec 24, 2006 03:17 PM
