need body work info
Old Jan 6, 2012 | 10:24 AM
dogdog130's Avatar
Default need body work info
i am trying to save as much money as i can so i want to know if i can put this dent in from the inside or should i just pop it with a dent puller it right behind the front door and the other is a broken part under the tail light do i need to fiberglass it or can i just replace it here are the pictures
Old Jan 6, 2012 | 01:35 PM
Grandpaswagon's Avatar
For the dent, I would use a stud puller. It comes with copper studs that get spot welded to the outside, and you use a slide hammer to pull them out. They work awesome and you don't have a bunch of holes to weld-up afterward. This is the one I have used Stud Welder Dent Repair Kit
For the rear panel you can do a good repair with fiberglass and filler. Or just get an entire panel from you local wrecking yard.
Pyroted
May 30, 2014 11:49 AM
greenmachine96
May 8, 2011 08:20 PM
94z28chevy
82-92 V8 Tech
May 3, 2008 12:22 AM
importmd
Mar 27, 2008 12:21 AM
thebandit110
Apr 15, 2007 06:23 PM
