need advice on basic engine building
Old Aug 29, 2011 | 03:46 PM
supafly147258's Avatar
Default need advice on basic engine building
ok so I got a 1995 Z28 and I am planning on eventually building the car up but before I get into any heavy building I was wondering what are some moderate things I can do to the engine to gain some noticeable gain in horse power?
Old Aug 29, 2011 | 09:45 PM
3800camaro's Avatar
Headers, catback, cold air. Those are the main 3 things to get power. Then cam, heads, port and polish intake and heads, tune.... List goes on. Hope this helps you a little.
Old Aug 29, 2011 | 11:37 PM
vanquishfist's Avatar
+1 What he said.
And depending on how much you like corners, I suggest upgrading the shocks. The list can go on for that too...
Old Aug 30, 2011 | 07:56 AM
torque_is_good's Avatar
replace the torn seats or buy the nice covers from coverking at amazon.com
sure, they cost a pretty penny but they look nicer than your torn seats
replace the worn rug
sand it down and repaint and clear. Get rid of the salad shooter rims
replace that slow window motor. You'll appreciate that more than 10 HP
and don't use 87 or 89 octane fuel
Old Aug 30, 2011 | 08:28 AM
Grandpaswagon's Avatar
Sounds like you know his new car....
Old Aug 30, 2011 | 02:50 PM
ok sounds like a plan thanks for the advice and also about the shocks what type of coil overs would you suggest I use?
Old Aug 30, 2011 | 04:28 PM
Catmaigne's Avatar
I find bricks make the best suspension.
Old Aug 30, 2011 | 07:16 PM
ok ill look into getting some
Old Aug 30, 2011 | 11:23 PM
If you decide bricks are too soft for your taste, I would suggest SLP Bilsteins or Konis if you have the money.
Old Aug 31, 2011 | 12:19 AM
ok ill look into it because I dont have all the money at once but I plan on building this car over the next 2 years or so
Saundra Hightower
67-69 V8 Tech
Nov 22, 2011 04:48 PM
camaro maniac
Sep 18, 2007 11:26 AM
hurley870
Jul 28, 2007 11:00 PM
maxxiepad
Mar 2, 2007 03:00 PM
