Motor and transmission swap
I have a 2001 Camaro automatic blown motor and I have a wrecked 2002 Camaro manual . i am wanting to swap the motor and transmission from the 2002 and install it in the 2001. i know from reading other threads that it is costly and a lot to do. i was wondering since i have everything to convert how complicated will it be or is it not worth it and just change the motor.
As long as the engines are the same, it's straight drop in. Your hard part will be mounting the clutch pedals and master and even that shouldn't be too hard since the hole is already dimpled for the master.
v6baser
Sep 6, 2014 09:51 PM
