motor swap
Old Nov 25, 2007 | 08:17 PM
crgm101's Avatar
Default motor swap
alright i know everybody say's not to do it but i got a free 95 3.4lt camaro with a blown valve in the motor the guy i got it from. got it have way apart and left it for a year now theres water in the oil and i believe the engine is seized. i have a free 85 chevelle motor 5lt and was wondering if this would fit or should i get a ls1 from my friend i don't believe any v8 will fit the stock auto tranny but i'm not sure whattranny this carhas in it.if anyone can help it would be much appreciated
Old Nov 25, 2007 | 10:24 PM
purpl96's Avatar
Default RE: motor swap
if you definitely want to keep the car and not put a lot into it i would go to a junk yard and pull a 3.8 out of a wrecked camaro/firebird and instead just drop that in, if your looking for an easy fix.because that way you can just bolt up the tranny thats currently in it and i think the engine cradle is the same but im not positive on that. anything will fit with the right amount of money and time.if you know you want a v8 then i would just sell the car and buy a z28. but if your looking for a project then i would just try to pick up a wrecked 4th gen. z28 and just salvage everypart of it and put it onto the 95 3.4 includingthe motor, tranny, rear-end, and the k member along with all the other front end suspension and motor mounts. that stock auto tranny i believe is the 4l60e and i don't even know if that can handle a v8 even if it's built right. i've thought about putting an lt1 into my 96 3.8 but im not going to until i find a z28 donor car to do it with.
riverman95-99
Feb 12, 2012 01:59 PM
sandvipr
Apr 25, 2011 12:03 PM
mregulater
82-92 V8 Tech
Mar 10, 2009 11:47 AM
dmolaver15
82-92 V8 Tech
Dec 20, 2008 08:46 PM
Camroman250
Apr 30, 2006 12:17 PM
