Markings on crankshaft
Old Sep 4, 2010 | 06:38 PM
  #21
peacher57's Avatar
I had a 2800 stall on my last camaro and it slipped alot.....I didn't like it......think maybe a 2500 would work?
Old Sep 5, 2010 | 12:01 AM
  #22
Originally Posted by peacher57
Yep......I spun the cam around no problem.......do I need to turn the assembly with the timing gears meshed to the crank in time? It's not a stroker......just a stock 400 with a beefy cam......
Just spinning the cam doesn't show your clearance. You need to turn your entire rotating assembly to make sure the rods clear the cam as they come around. I know you don't have a stroker motor. But a stroker uses a 400 crank just like you have in your 400, which is why you want to double check clearances.
Old Sep 6, 2010 | 08:35 PM
  #23
peacher57's Avatar
I'm not Racing it Pete.....I just want it to sound racey.....A high stall is a good suggestion though. Lower diff gears too.
67Harbor
Apr 3, 2010 06:32 PM
bobarian91
Jan 20, 2009 09:44 PM
eagans2002
Dec 1, 2008 07:52 AM
benz660r
Aug 9, 2006 12:12 AM
GR95Camaro
Mar 25, 2006 06:17 PM
