LT4 intake manifold on LT1?
will an intake manifold from an LT4 fit on my 96 z28? i hear that lt4 parts fit onto lt1 engines without any problems. but not sure if this is true also about how much power/performance could i expect from this swap?
i think u have to have it modified to make it fit. give lloyd a call and ask what all needs to be done. may be worth having the heads and intake done at the same time.
http://www.elliottsportworks.com/lt1.html
The bolts will line up OK, but the ports of a stock LT4 manifold will not mate properly with the ports on stock LT1 heads. There will be a flow disruption when transitioning from large to small. Get LT4 heads or port the Lt1 heads to get a match.
